Ir para o conteúdo principal
VTech Learning Tunes Karaoke Mode Selector Replacement
O que você precisa
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: passo 1, imagem 1 %32
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, imagem 2 %32
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 3, imagem 1 %32
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 5, imagem 1 %32
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, imagem 2 %32
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, imagem 2 %32
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Conclusão
Adam Chaberek
Membro desde: 02/09/16
137 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membro de USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 444
