Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Wristband Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: passo 1, imagem 1 %32
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 2, imagem 1 %32
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 3, imagem 1 %32
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 4, imagem 1 %32
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Conclusão
Sydney
Membro desde: 10/25/18
368 Reputação
Autoria de 2 guias
Equipe
2Comentários do guia
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - Responder
Where can I buy a replacement wristband for dx2? Thanks
Ari - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 71
Ao todo: 7,834
