Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Wristband Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: passo 1, imagem 1 %32
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 2, imagem 1 %32
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 3, imagem 1 %32
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: passo 4, imagem 1 %32
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Conclusão
Sydney
Membro desde: 10/25/18
344 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
Membros da 4
Autoria de 7 guias
Um comentário
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 52
Duração total: 7,258
