Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Speakers Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: passo 1, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: passo 1, imagem 2 %32
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 2, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 2, imagem 2 %32
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 3, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 3, imagem 2 %32
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 4, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 4, imagem 2 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 4, imagem 3 %32
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Motherboard: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 6, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 6, imagem 2 %32
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 7, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Speakers Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Speakers: passo 8, imagem 1 %32
    • Carefully desolder the speaker from the board.
    • Be careful to not desolder the battery cable.
Conclusão
Jessica Richard
Membro desde: 10/25/18
512 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
Membros da 4
Autoria de 7 guias
Um comentário
hi, where did you buy the spare speaker?
minhhai79 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 749
