Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Motherboard Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: passo 1, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: passo 1, imagem 2 %32
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 2, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 2, imagem 2 %32
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 3, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 3, imagem 2 %32
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 4, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 4, imagem 2 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 4, imagem 3 %32
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 6, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 6, imagem 2 %32
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 7, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
Conclusão
5 outras pessoas executaram este guia.
Jessica Richard
Membro desde: 10/25/18
515 Reputação
Autoria de 4 guias
Equipe
3Comentários do guia
This shows how to take the motherboard out, but how to I get a replacement motherboard? I don’t see anywhere that I can purchase one…
ltiede12 - Responder
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
Asher Kobin - Responder
Which screen is the motherboard connected to bcause I have to replace it cause it is broken
TECH DUDE - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 4,013
