Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: passo 1, imagem 1 %32
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: passo 2, imagem 1 %32
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: passo 3, imagem 1 %32
    • Once successful, pull the remaining faceplate off from the watch.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Richard
Membro desde: 10/25/18
512 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
Membros da 4
Autoria de 7 guias
4 comentários
Where can I find a faceplate?
Sammi Schummer - Responder
Where can you buy a replacement face plate?
Natalie - Responder
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - Responder
Where can I get a replacement faceplate please
Steph Crowe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 2,538
