Introdução
If one of the cameras on your device is broken, cracked, or damaged in any way, the following guide will show you how to replace the camera.
O que você precisa
Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
Carefully lift the clips and slide the cameras out.
Conclusão
