Ir para o conteúdo principal
VTech Kidizoom Smartwatch DX2 Battery Replacement
O que você precisa
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: passo 1, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: passo 1, imagem 2 %32
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 2, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 2, imagem 2 %32
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 3, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 3, imagem 2 %32
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 4, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 4, imagem 2 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 4, imagem 3 %32
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 6, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 6, imagem 2 %32
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 7, imagem 1 %32 VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: passo 8, imagem 1 %32
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: passo 9, imagem 1 %32
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Conclusão
Jessica Richard
Membro desde: 10/25/18
515 Reputação
Autoria de 4 guias
Equipe
5Comentários do guia
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Responder
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Can I cut the wires connected?
TECH DUDE - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 112
Ao todo: 10,983
