Ir para o conteúdo principal
VTech Kidizoom Camera Connect Speaker Replacement
O que você precisa
  1. VTech Kidizoom Camera Connect Speaker Replacement, Front Case: passo 1, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement, Front Case: passo 1, imagem 2 %32
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Speaker Replacement: passo 2, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 2, imagem 2 %32
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Speaker Replacement: passo 3, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 3, imagem 2 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 3, imagem 3 %32
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Speaker Replacement: passo 4, imagem 1 %32
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Speaker Replacement, Motherboard: passo 5, imagem 1 %32
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Speaker Replacement: passo 6, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 6, imagem 2 %32
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Speaker Replacement: passo 7, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 7, imagem 2 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 7, imagem 3 %32
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Speaker Replacement: passo 8, imagem 1 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 8, imagem 2 %32 VTech Kidizoom Camera Connect Speaker Replacement: passo 8, imagem 3 %32
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
  9. VTech Kidizoom Camera Connect Speaker Replacement, Speaker: passo 9, imagem 1 %32
    • The speaker is glued in so you must use the metal spudger to break the seal made by the glue.
  10. VTech Kidizoom Camera Connect Speaker Replacement: passo 10, imagem 1 %32
    • Once the seal is broken the speaker should move freely. Carefully lift and remove the speaker along with its attached red and black wires.
Conclusão
Uma outra pessoa concluiu este guia.
Justin Sanchez
Membro desde: 02/08/16
493 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 508
