Introdução
Use this guide to remove and replace the speaker.
O que você precisa
Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
The speaker is glued in so you must use the metal spudger to break the seal made by the glue.
Uma outra pessoa concluiu este guia.
