Ir para o conteúdo principal
VTech Kidizoom Camera Connect Shutter Button Replacement
O que você precisa
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, imagem 2 %32
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, imagem 2 %32
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 2 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 3 %32
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 4, imagem 1 %32
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: passo 5, imagem 1 %32
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 6, imagem 1 %32
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, imagem 2 %32
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Justin Sanchez
Membro desde: 02/08/16
520 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 897
