Ir para o conteúdo principal
VTech Kidizoom Camera Connect Front Case Replacement
O que você precisa
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: passo 1, imagem 1 %32 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: passo 1, imagem 2 %32
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: passo 2, imagem 1 %32 VTech Kidizoom Camera Connect Front Case Replacement: passo 2, imagem 2 %32
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: passo 3, imagem 1 %32 VTech Kidizoom Camera Connect Front Case Replacement: passo 3, imagem 2 %32 VTech Kidizoom Camera Connect Front Case Replacement: passo 3, imagem 3 %32
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: passo 4, imagem 1 %32
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Foster
Membro desde: 02/14/16
324 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 24
Ao todo: 4,626
