Introdução
Exercise caution when soldering the speaker to and from the motherboard, as you could possibly melt the motherboard. This replacement is one of the most difficult, as it requires expertise with a soldering iron and a steady hand.
O que você precisa
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Use the soldering iron to reheat the solder around the speakers' prongs on the motherboard.
2 comentários
HTC one camara
