Introdução
The battery may sometimes malfunction in a device and may need to be replaced for the device to function again.
O que você precisa
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Use the soldering iron to unsolder the battery wires connected to the motherboard by reheating the existing solder.
8 outras pessoas executaram este guia.
2 comentários
Where will get new batteries for same.
Where does one buy a replacement battery? And what type of battery is it?
