Ir para o conteúdo principal
VTech InnoTab Max Motherboard Replacement
O que você precisa
  1. VTech InnoTab Max Motherboard Replacement, Cover: passo 1, imagem 1 %32 VTech InnoTab Max Motherboard Replacement, Cover: passo 1, imagem 2 %32 VTech InnoTab Max Motherboard Replacement, Cover: passo 1, imagem 3 %32
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Motherboard Replacement: passo 2, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 2, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 2, imagem 3 %32
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Motherboard Replacement: passo 3, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 3, imagem 2 %32
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Motherboard Replacement: passo 4, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 4, imagem 2 %32
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Motherboard Replacement, Battery: passo 5, imagem 1 %32
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Motherboard Replacement: passo 6, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 6, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Motherboard Replacement: passo 7, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 7, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 7, imagem 3 %32
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Motherboard Replacement: passo 8, imagem 1 %32
    • The battery is now fully disconnected.
  9. VTech InnoTab Max Motherboard Replacement, Camera: passo 9, imagem 1 %32
    • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
  10. VTech InnoTab Max Motherboard Replacement: passo 10, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
    • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
  11. VTech InnoTab Max Motherboard Replacement: passo 11, imagem 1 %32
    • The camera is now removed completely removed from the device.
  12. VTech InnoTab Max Motherboard Replacement, Screen: passo 12, imagem 1 %32 VTech InnoTab Max Motherboard Replacement, Screen: passo 12, imagem 2 %32
    • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
    • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
  13. VTech InnoTab Max Motherboard Replacement: passo 13, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 13, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 13, imagem 3 %32
    • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
  14. VTech InnoTab Max Motherboard Replacement: passo 14, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 14, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 14, imagem 3 %32
    Comprar
    • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
    • Be careful not to tear the film when pulling.
  15. VTech InnoTab Max Motherboard Replacement: passo 15, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 15, imagem 2 %32
    • Once unclipped from the motherboard the screen should be entirely free from the device
  16. VTech InnoTab Max Motherboard Replacement, Motherboard: passo 16, imagem 1 %32
    • Remove the circled screws that are holding down the motherboard and components.
    • Every component that will need to be unscrewed will have wires running to it from the motherboard. These wires will not be disconnected.
  17. VTech InnoTab Max Motherboard Replacement: passo 17, imagem 1 %32 VTech InnoTab Max Motherboard Replacement: passo 17, imagem 2 %32 VTech InnoTab Max Motherboard Replacement: passo 17, imagem 3 %32
    • With all of the screws out, lift up the speaker, the two visible bronze plates, and the small green chip at the top.
    • Do not try to disconnect any of the wires running to these devices, as you will not be able to reconnect them.
    • All of these components can be located by following wires leaving the motherboard.
  18. VTech InnoTab Max Motherboard Replacement: passo 18, imagem 1 %32
    • With all of these components out of their place, lift up the motherboard to reveal one more bronze plate.
    • Remove the screws holding down this plate, and remove it with the rest of the motherboard.
  19. VTech InnoTab Max Motherboard Replacement: passo 19, imagem 1 %32
    • All components should be free from the device, and you can now completely remove the motherboard.
Conclusão
Jacob Schioppo
Membro desde: 02/15/17
539 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S5-G5, Lacy Spring 2017 Membro de USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,938
