Ir para o conteúdo principal
VTech InnoTab 2s Speaker Replacement
O que você precisa
  1. VTech InnoTab 2s Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Speaker Replacement: passo 2, imagem 1 %32 VTech InnoTab 2s Speaker Replacement: passo 2, imagem 2 %32
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Speaker Replacement: passo 3, imagem 1 %32 VTech InnoTab 2s Speaker Replacement: passo 3, imagem 2 %32 VTech InnoTab 2s Speaker Replacement: passo 3, imagem 3 %32
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Speaker Replacement: passo 4, imagem 1 %32 VTech InnoTab 2s Speaker Replacement: passo 4, imagem 2 %32
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Speaker Replacement: passo 5, imagem 1 %32 VTech InnoTab 2s Speaker Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2s Speaker Replacement, Motherboard: passo 6, imagem 1 %32
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2s Speaker Replacement: passo 7, imagem 1 %32
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2s Speaker Replacement: passo 8, imagem 1 %32
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2s Speaker Replacement: passo 9, imagem 1 %32
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2s Speaker Replacement: passo 10, imagem 1 %32
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2s Speaker Replacement, Speaker: passo 11, imagem 1 %32
    • Desolder these two points from the circuit board.
    • A soldering guide provided by iFixit can be found here: Soldering Skills.
  12. VTech InnoTab 2s Speaker Replacement: passo 12, imagem 1 %32
    • Remove the two screws that are holding down the speaker.
  13. VTech InnoTab 2s Speaker Replacement: passo 13, imagem 1 %32
    • Desolder the two wires that are connected to the speaker.
    • A soldering guide offered by IFIXIT can be found here: Soldering Skills.
Conclusão
Esthevan Romeiro
Membro desde: 10/06/16
261 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 5-1, Lacy Fall 2016 Membro de USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Membros
Autoria de 12 guias
1Comentário do guia
Thank you for this guide. I have a Vtech (ELC) toy flip phone, which has similar issue. I think your guide is incomplete, has only 13 steps and stops at desoldering the speaker. What speaker shall I get, does it matter, or just the size matters? Thank you!
Scream - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 430
