Ir para o conteúdo principal
VTech InnoTab 2s Back Panel Replacement
O que você precisa
  1. VTech InnoTab 2s Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Back Panel Replacement: passo 2, imagem 1 %32 VTech InnoTab 2s Back Panel Replacement: passo 2, imagem 2 %32
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Back Panel Replacement: passo 3, imagem 1 %32 VTech InnoTab 2s Back Panel Replacement: passo 3, imagem 2 %32 VTech InnoTab 2s Back Panel Replacement: passo 3, imagem 3 %32
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Back Panel Replacement: passo 4, imagem 1 %32 VTech InnoTab 2s Back Panel Replacement: passo 4, imagem 2 %32
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Back Panel Replacement: passo 5, imagem 1 %32 VTech InnoTab 2s Back Panel Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Ricardo Espinosa
Membro desde: 10/06/16
221 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-1, Lacy Fall 2016 Membro de USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 408
