Ir para o conteúdo principal
VTech CS6719-2 Circuit Board Replacement
O que você precisa
  1. VTech CS6719-2 Circuit Board Replacement, Battery: passo 1, imagem 1 %32 VTech CS6719-2 Circuit Board Replacement, Battery: passo 1, imagem 2 %32
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Circuit Board Replacement: passo 2, imagem 1 %32
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Circuit Board Replacement: passo 3, imagem 1 %32
    • Unplug the battery input cable.
  4. VTech CS6719-2 Circuit Board Replacement: passo 4, imagem 1 %32
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Circuit Board Replacement, Circuit Board: passo 5, imagem 1 %32 VTech CS6719-2 Circuit Board Replacement, Circuit Board: passo 5, imagem 2 %32
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Circuit Board Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Circuit Board Replacement: passo 7, imagem 1 %32 VTech CS6719-2 Circuit Board Replacement: passo 7, imagem 2 %32
    • Remove the two 9mm screws located inside the back cover at the top.
Conclusão
3 outras pessoas executaram este guia.
Benjamin Field
Membro desde: 02/08/16
270 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-4, Baechle Spring 2016 Membro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Membros
Autoria de 16 guias
1Comentário do guia
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
Jason Bellchamber - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 649
