Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Gently pull up on the rear panel.
Rest the laptop open on the table.
Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
Five 7.3mm
Two 6.0mm
Once the screws have been removed, the mode switch assembly can be removed easily.
You need this spring to find a matching replacement if it is in anyway damaged.
