Ir para o conteúdo principal
VTech Baby's Learning Laptop Mode Switch Replacement
O que você precisa
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mode Switch Replacement: passo 2, imagem 1 %32
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mode Switch Replacement: passo 3, imagem 1 %32
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mode Switch Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop Mode Switch Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: passo 5, imagem 1 %32 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: passo 5, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, imagem 1 %32 VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, imagem 2 %32 VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, imagem 3 %32
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mode Switch Replacement: passo 7, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
  8. VTech Baby's Learning Laptop Mode Switch Replacement: passo 8, imagem 1 %32
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
Conclusão
Scott Parkinson
Membro desde: 09/09/15
113 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 642
