Ir para o conteúdo principal
VTech Baby's Learning Laptop Speaker Replacement
O que você precisa
  1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Speaker Replacement: passo 2, imagem 1 %32
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Speaker Replacement: passo 3, imagem 1 %32
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Speaker Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop Speaker Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Speaker Replacement, Speaker: passo 5, imagem 1 %32 VTech Baby's Learning Laptop Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
  6. VTech Baby's Learning Laptop Speaker Replacement: passo 6, imagem 1 %32 VTech Baby's Learning Laptop Speaker Replacement: passo 6, imagem 2 %32
    • Remove the two 6 mm screws from the device.
    • Remove the speaker.
    • Be careful not to damage the wiring.
Conclusão
Jordan Smith
Membro desde: 09/03/15
210 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
Membros da 4
Autoria de 14 guias
2 comentários
Where to buy the replacement speaker
hadbuckley - Responder
Where can you buy the replacement speaker please. I live in Sydney Australia
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,224
