Ir para o conteúdo principal
VTech Baby's Learning Laptop Mouse Replacement
O que você precisa
  1. VTech Baby's Learning Laptop Mouse Replacement, Battery and Rear Panel: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mouse Replacement: passo 2, imagem 1 %32
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mouse Replacement: passo 3, imagem 1 %32
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mouse Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mouse Replacement, Mouse: passo 5, imagem 1 %32 VTech Baby's Learning Laptop Mouse Replacement, Mouse: passo 5, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mouse Replacement: passo 6, imagem 1 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 6, imagem 2 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 6, imagem 3 %32
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mouse Replacement: passo 7, imagem 1 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 7, imagem 2 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 7, imagem 3 %32
    • Locate and remove the following screws:
    • Two 11.0mm Phillips #2.
    • Two 7.3mm Phillips #0.
    • Remove the top of the mouse which will separate from the under side once the screws are removed.
    • The metal connection near the yellow screws on the top left of the mouse assembly falls out very easily. Make sure to replace the metal connection with the prong pointing up. Otherwise, the mouse will not work correctly.
  8. VTech Baby's Learning Laptop Mouse Replacement: passo 8, imagem 1 %32 VTech Baby's Learning Laptop Mouse Replacement: passo 8, imagem 2 %32
    • Lift the springs up from the screw pegs with a plastic opening tool.
    • Remove the final part of the mouse.
    • Before reassembly, see the note on the previous step.
Conclusão
Justin Schanze
Membro desde: 09/03/15
230 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,001
