Ir para o conteúdo principal
VTech Baby's Learning Laptop LEDs Replacement
O que você precisa
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop LEDs Replacement: passo 2, imagem 1 %32
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop LEDs Replacement: passo 3, imagem 1 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 3, imagem 2 %32
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
  4. VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 2 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 3 %32
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
  5. VTech Baby's Learning Laptop LEDs Replacement: passo 5, imagem 1 %32
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
  6. VTech Baby's Learning Laptop LEDs Replacement: passo 6, imagem 1 %32
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
Conclusão
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 905
