Introdução
Un-stick an 11w Vex V5 smart motor that has seized up
This method will void the warranty and competition legality of your motor if you complete this process.
- Before opening the motor attempt to spin the motor with a high-strength axle and large wheel.
- This fix may only be temporary. The reliability of this motor is not guaranteed when completing this process.
O que você precisa
use a Small Phillips head screwdriver to remove the top case.
simply pull the cartridge out of the motor.
NOTE: my motor had no case when I got it so I only had the attached PDF for images.
Remove the 4 screws holding the top case on the motor.
Once the screws are removed you can pull the 2 pieces apart.
Remove the 2 Phillips head screws holding the bottom case on.
Pull the bottom case off.
Use your fingers, a small flathead screwdriver, or a spudger to remove the center gear.
1. Tap the small metal gear and metal shaft on the other side of the motor.
2. Grip the metal gear with pliers and twist 1 full revolution or until the motor spins freely by hand.
