Ir para o conteúdo principal
Using a Jack
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Using a Jack, Using a Jack: passo 1, imagem 1 %32 Using a Jack, Using a Jack: passo 1, imagem 2 %32
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. Using a Jack: passo 2, imagem 1 %32 Using a Jack: passo 2, imagem 2 %32
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
Conclusão
To remove jack stands, follow guide in reverse order, remembering that lowering and raising the Pneumatic Jack require different actions.
Matt Ondriezek
Membro desde: 04/14/14
486 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-35, Maness Spring 2014 Membro de Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 919
