Ir para o conteúdo principal
Using a Floor Jack
O que você precisa
  1. Using a Floor Jack, Using a Floor Jack: passo 1, imagem 1 %32 Using a Floor Jack, Using a Floor Jack: passo 1, imagem 2 %32
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. Using a Floor Jack, Using floor jack to lift car.: passo 2, imagem 1 %32
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. Using a Floor Jack: passo 3, imagem 1 %32
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. Using a Floor Jack: passo 4, imagem 1 %32
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
Conclusão
8 outras pessoas executaram este guia.
Shaun MacDonald
Membro desde: 10/03/12
2.654 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 24-27, Regan Fall 2012 Membro de Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 63
Últimos 30 dias: 236
Ao todo: 43,553
