Introdução
Upgrade up to 16 GB of RAM memory in your 21.5" iMac
All photos are property of iFixit
O que você precisa
First you need to remove the glue from the edge of the iMac
Use a Guitar Pick around the screen to remove the glue
Once you are sure the adhesive is removed, use two heavy suction cups to lift the screen
Unplug these cables:
DisplayPort Cable
Power Cable
Lift the screen from the iMac
Remove the four Torx T10 screws
Unplug the SATA cables and remove the hard drive
Remove these 3 Torx T10 screws
After you remove the screws, remove these cables
Fan Cable
Unstick and unplug the camera cable
Remove these 2 Torx T10 screws
Unplug these 2 cables
Unplug 2 more cable below the power board by pressing the clip
Unscrew 3 Torx T8 screws from the heatsink, then remove the logic board from the iMac
To reassemble your device, follow these instructions in reverse order remembering to re-glue the screen.
11 outras pessoas executaram este guia.
