Ir para o conteúdo principal
Untracked Bifold Door Pin Replacement
O que você precisa
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: passo 1, imagem 1 %32
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: passo 2, imagem 1 %32
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: passo 3, imagem 1 %32
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: passo 4, imagem 1 %32 Untracked Bifold Door Pin Replacement: passo 4, imagem 2 %32
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: passo 5, imagem 1 %32
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: passo 6, imagem 1 %32
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: passo 7, imagem 1 %32
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: passo 8, imagem 1 %32
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: passo 9, imagem 1 %32
    • When completed, the bifold doors should close and be positioned within the tracking.
Conclusão
Catelyn Carpenter
Membro desde: 01/16/20
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 34
Duração total: 1,718
