Ir para o conteúdo principal
Unsticking SteelSeries Nimbus Triggers
O que você precisa
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: passo 1, imagem 1 %32
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: passo 2, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 2, imagem 2 %32
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: passo 3, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 3, imagem 2 %32 Unsticking SteelSeries Nimbus Triggers: passo 3, imagem 3 %32
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: passo 4, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 4, imagem 2 %32
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: passo 5, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 5, imagem 2 %32 Unsticking SteelSeries Nimbus Triggers: passo 5, imagem 3 %32
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: passo 6, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 6, imagem 2 %32 Unsticking SteelSeries Nimbus Triggers: passo 6, imagem 3 %32
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: passo 7, imagem 1 %32 Unsticking SteelSeries Nimbus Triggers: passo 7, imagem 2 %32
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
Conclusão
8 outras pessoas executaram este guia.
Jonathan
Membro desde: 03/13/13
464 Reputação
Autoria de 2 guias
4 comentários
Great, concise fix instructions!
Brian Pippen - Responder
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Responder
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Responder
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 56
Duração total: 6,150
