Pular para o conteúdo principal
Introdução
This guide will show you how to carefully disassemble the Unnecto Drone M with easily available tools.
  1. Place the phone facedown on a cleared work area Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Grip the top right corner of the battery.
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Remove the four screws on the back of the phone using a Philips 000 screwdriver
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Separate the frame evenly using a plastic opening tool.
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  6. Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard. Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  7. Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  8. Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  9. Set aside the circuit board from the screen protector. Set aside the circuit board from the screen protector.
    • Set aside the circuit board from the screen protector.
Conclusão
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 33
