Ir para o conteúdo principal
Unnecto Drone M Digitizer Replacement
O que você precisa
  1. Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: passo 1, imagem 1 %32 Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: passo 1, imagem 2 %32
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Digitizer Replacement: passo 2, imagem 1 %32
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Digitizer Replacement: passo 3, imagem 1 %32
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Digitizer Replacement: passo 4, imagem 1 %32
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Digitizer Replacement: passo 5, imagem 1 %32 Unnecto Drone M Digitizer Replacement: passo 5, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Digitizer Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Digitizer Replacement: passo 7, imagem 1 %32
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Digitizer Replacement: passo 8, imagem 1 %32 Unnecto Drone M Digitizer Replacement: passo 8, imagem 2 %32
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Digitizer Replacement, Digitizer: passo 9, imagem 1 %32 Unnecto Drone M Digitizer Replacement, Digitizer: passo 9, imagem 2 %32
    • Replace the old plastic screen with the new one.
    • Reassemble the phone by following the steps in reverse order.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 33
Ao todo: 483
