Introdução
Unihertz Titan Pocket
O que você precisa
Use a Torx T5 screwdriver to remove the 3 screws.
Remove the Sim tray.
Insert the opening pick into the gap between the body and the back plate. Then open the gap so that the latch comes out.
There are three latches on the left and right, one on the top and two on the bottom.
Remove the 3 screws using a Phillips #000 screwdriver.
Use the opening tool to open the gap.
Remove the 2 screws using a Phillips #000 screwdriver.
Lift the top part with the pointed part of the Spudger.
Disconnect the 6 connectors.
Remove the 5 screws using a Phillips #000 screwdriver.
Use the Spudger to lift the top of the motherboard.
Insert a thin thing such as a Sim pin through the hole where the screw was removed and push the keyboard out.
Remove the 17 plastic rivets to separate the board and keyboard.
To reassemble the device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
glwps está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
