Ir para o conteúdo principal
Uniden UTAB71 Camera Replacement
O que você precisa
  1. Uniden UTAB71 Camera Replacement, Camera: passo 1, imagem 1 %32 Uniden UTAB71 Camera Replacement, Camera: passo 1, imagem 2 %32
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: passo 2, imagem 1 %32 Uniden UTAB71 Camera Replacement: passo 2, imagem 2 %32
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: passo 3, imagem 1 %32
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: passo 4, imagem 1 %32 Uniden UTAB71 Camera Replacement: passo 4, imagem 2 %32 Uniden UTAB71 Camera Replacement: passo 4, imagem 3 %32
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Conclusão
Ryan Jewell
Membro desde: 10/20/16
422 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 167
