O que você precisa
Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
If sticky residue is not the problem the next step is to visit http://udn.factoryoutletstore.com and search for the UNIDEN EXP 371 and order a new dial pad.
