Ir para o conteúdo principal
Uniden EXP 371 Keypad Replacement
O que você precisa
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: passo 1, imagem 1 %32
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: passo 2, imagem 1 %32 Uniden EXP 371 Keypad Replacement: passo 2, imagem 2 %32 Uniden EXP 371 Keypad Replacement: passo 2, imagem 3 %32
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: passo 3, imagem 1 %32 Uniden EXP 371 Keypad Replacement: passo 3, imagem 2 %32
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: passo 4, imagem 1 %32
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: passo 5, imagem 1 %32 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: passo 5, imagem 2 %32
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: passo 6, imagem 1 %32
Conclusão
Lucas Mohsen
Membro desde: 10/31/14
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 148
