Ir para o conteúdo principal
Uniden D1688 multistation and handset disassembly
O que você precisa
  1. Uniden D1688 multistation and handset disassembly, Uniden D1688 multistation and handset disassembly: passo 1, imagem 1 %32
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 multistation and handset disassembly: passo 2, imagem 1 %32
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
  3. Uniden D1688 multistation and handset disassembly: passo 3, imagem 1 %32
    • Unscrew the 3 screws (Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 multistation and handset disassembly: passo 4, imagem 1 %32
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 multistation and handset disassembly: passo 5, imagem 1 %32
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 multistation and handset disassembly: passo 6, imagem 1 %32
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 multistation and handset disassembly: passo 7, imagem 1 %32
    • Remove rubber keyboard underlay from top shell.
  8. Uniden D1688 multistation and handset disassembly: passo 8, imagem 1 %32
    • Push the plastic keyboard pieces out of the top shell.
  9. Uniden D1688 multistation and handset disassembly: passo 9, imagem 1 %32
    • Unscrew bottom shell circuit board screws (Head size: 4mm Length: 8.6mm).
  10. Uniden D1688 multistation and handset disassembly: passo 10, imagem 1 %32
    • The disassembly of the phone base is complete!
    • Now this guide will move on to taking apart one of the handsets.
  11. Uniden D1688 multistation and handset disassembly: passo 11, imagem 1 %32
    • Slide the battery cover off of the handset, and unplug the battery.
  12. Uniden D1688 multistation and handset disassembly: passo 12, imagem 1 %32
    • Remove the battery, and unscrew the two screws (Head Size: 4mm Length: 8.6 mm).
  13. Uniden D1688 multistation and handset disassembly: passo 13, imagem 1 %32
    • Use spudger to separate the phone shell.
  14. Uniden D1688 multistation and handset disassembly: passo 14, imagem 1 %32
    • Unscrew the two screws (Head Size: 4mm Length: 8.6mm) on the bottom shell keeping the speaker locking pin in place.
Conclusão
Nicholas Weeks
Membro desde: 01/27/15
101 Reputação
Autoria de 1 guia
Equipe
Pasco Hernando, Team 1-4, Prince Winter 2015 Membro de Pasco Hernando, Team 1-4, Prince Winter 2015
PHSC-PRINCE-W15S1G4
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 522
