Introdução
We are going to teach you how to remove bottom shell circuit board. By removing this, you will learn how to dissemble the speaker.
O que você precisa
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
Unscrew bottom shell circuit board screws(Head size: 4mm Length: 8.6mm).
