Ir para o conteúdo principal
Uniden D1688 Bottom Circuit Board Replacement
O que você precisa
  1. Uniden D1688 Bottom Circuit Board Replacement, Uniden D1688 Base Replacement: passo 1, imagem 1 %32
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Bottom Circuit Board Replacement: passo 2, imagem 1 %32 Uniden D1688 Bottom Circuit Board Replacement: passo 2, imagem 2 %32
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
  3. Uniden D1688 Bottom Circuit Board Replacement, Top Circuit Board: passo 3, imagem 1 %32
    • Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 Bottom Circuit Board Replacement: passo 4, imagem 1 %32
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 Bottom Circuit Board Replacement: passo 5, imagem 1 %32
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 Bottom Circuit Board Replacement: passo 6, imagem 1 %32
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 Bottom Circuit Board Replacement: passo 7, imagem 1 %32
    • Remove top shell circuit board by lifting the circuit board out of the case
  8. Uniden D1688 Bottom Circuit Board Replacement, Bottom Circuit Board: passo 8, imagem 1 %32
    • Unscrew bottom shell circuit board screws(Head size: 4mm Length: 8.6mm).
  9. Uniden D1688 Bottom Circuit Board Replacement: passo 9, imagem 1 %32
    • Lift bottom circuit board from the bottom shell.
Conclusão
justin
Membro desde: 01/26/15
419 Reputação
Autoria de 4 guias
Equipe
Pasco Hernando, Team 1-4, Prince Winter 2015 Membro de Pasco Hernando, Team 1-4, Prince Winter 2015
PHSC-PRINCE-W15S1G4
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 320
