Introdução
In this guide, you will learn how to dissemble the the base of Uniden D1688. You will learn how to use the spudger to open the case.
O que você precisa
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Uma outra pessoa concluiu este guia.
