Ir para o conteúdo principal
Uniden D1483-3BK Handset Keypad Replacement
O que você precisa
  1. Uniden D1483-3BK Handset Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Handset Keypad Replacement: passo 2, imagem 1 %32 Uniden D1483-3BK Handset Keypad Replacement: passo 2, imagem 2 %32
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Handset Keypad Replacement: passo 3, imagem 1 %32
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: passo 4, imagem 1 %32 Uniden D1483-3BK Handset Keypad Replacement, Handset Case: passo 4, imagem 2 %32
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Handset Keypad Replacement: passo 5, imagem 1 %32 Uniden D1483-3BK Handset Keypad Replacement: passo 5, imagem 2 %32 Uniden D1483-3BK Handset Keypad Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Handset Keypad Replacement: passo 6, imagem 1 %32 Uniden D1483-3BK Handset Keypad Replacement: passo 6, imagem 2 %32
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Handset Keypad Replacement: passo 7, imagem 1 %32 Uniden D1483-3BK Handset Keypad Replacement: passo 7, imagem 2 %32
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: passo 8, imagem 1 %32
    • Remove the rubber keypad from the front half of the handset case.
    • The keypad comes in two separate pieces.
Conclusão
6 outras pessoas executaram este guia.
Arbitrary Name
Membro desde: 01/28/15
1.083 Reputação
Autoria de 4 guias
Equipe
Penn State, Team 1-8, Kaschak Winter 2015 Membro de Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 221
