Introdução
This guide will show users how to fix the stretcher of an umbrella by using a thin piece of copper wire in place of where the rivet once was.
URL for half-hitch knot:
O que você precisa
5 outras pessoas executaram este guia.
6 comentários
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
6 months later and paperclip fix is still holding!
Thanks! A paperclip worked!
Mayra L. -
