Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Peças
Nenhum componente especificado.
  1. Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input). Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
  2. Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Slide out the rubber foot located on the bottom of the case.
    • Slide out the rubber foot located on the bottom of the case.
  4. Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
  5. Push against the side without end cap to slide the internal components out of the case. While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb. It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
  6. Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame. Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
    • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
  7. Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
    • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
    • It should come off after prying up the first tab.
  8. Carefully lift out the end panel. Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands. There is a bit of glue to hold the connection ribbon down.
    • Carefully lift out the end panel.
    • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
    • There is a bit of glue to hold the connection ribbon down.
  9. Remove the 5mm T6 screw holding the port assembly onto the end cap.
    • Remove the 5mm T6 screw holding the port assembly onto the end cap.
    • Unlike the flat top screw holding the metal housing, these screws are roundtop.
  10. Remove the old port assembly from the end cap.
    • Remove the old port assembly from the end cap.
    • Alternate Reassembly required, read on.
  11. Disconnect the Motherboard connection ribbon from the motherboard.
    • Disconnect the Motherboard connection ribbon from the motherboard.
    • The ribbon should no longer be connected at either end.
  12. Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
    • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
  13. Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
    • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
    • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
  14. Position the new port assembly on the end cap and reinsert the 5mm T6 screw. The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
    • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
    • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
  15. Reconnect the button ribbon connector on the top of the port assembly. Reconnect the button ribbon connector on the top of the port assembly.
    • Reconnect the button ribbon connector on the top of the port assembly.
  16. Reconnect the endcap to the plastic housing. While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
    • Reconnect the endcap to the plastic housing.
    • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
  17. Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
    • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
    • Finish reassembling in descending order starting at step 5.
Conclusão
To reassemble your device, follow steps 1 through 5 in reverse order.
4 outras pessoas concluíram este guia.
Noah Sadler
Membro desde: 01/04/2015
518 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro de Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Membros
10 Guias de autoria
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 13,869
