Ir para o conteúdo principal
USB 1020 Water Pump of DC 3.5-9V Replacement
O que você precisa
  1. USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: passo 1, imagem 1 %32 USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: passo 1, imagem 2 %32
    • Unplug the USB-C cord from the fountain.
    • Only proceed with dry hands to prevent being electrocuted.
  2. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 2, imagem 1 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 2, imagem 2 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 2, imagem 3 %32
    • Carefully pull out the water pump by pulling the wire from the reservoir located at the back.
  3. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 3, imagem 1 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 3, imagem 2 %32
    • Detach the old water pump from the tube by gently pulling on the pump.
  4. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 4, imagem 1 %32
    • Adjust the water pressure and flow on the new water pump.
    • Shift switch to the right to lower the pressure and left to increase the pressure.
  5. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 5, imagem 1 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 5, imagem 2 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 5, imagem 3 %32
    • Connect the new water pump to the tube.
    • Make sure you hear a click sound to ensure the connection is secure.
  6. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 6, imagem 1 %32
    • Place the new water pump into the reservoir.
  7. USB 1020 Water Pump of DC 3.5-9V Replacement: passo 7, imagem 1 %32 USB 1020 Water Pump of DC 3.5-9V Replacement: passo 7, imagem 2 %32
    • Plug in the USB-C cord to turn on the fountain.
    • Use dry hands to prevent being electrocuted.
Conclusão
With these easy-to-follow steps, you can seamlessly replace the water pump in your indoor fountain to keep it in excellent working condition.
Guneet Longia
Membro desde: 01/30/23
159 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 112
