Ir para o conteúdo principal
UE BOOM 2 Micro-USB Port Replacement
O que você precisa
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, imagem 1 %32 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, imagem 2 %32
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: passo 2, imagem 1 %32 UE BOOM 2 Micro-USB Port Replacement: passo 2, imagem 2 %32
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: passo 3, imagem 1 %32 UE BOOM 2 Micro-USB Port Replacement: passo 3, imagem 2 %32 UE BOOM 2 Micro-USB Port Replacement: passo 3, imagem 3 %32
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - Responder
  4. UE BOOM 2 Micro-USB Port Replacement: passo 4, imagem 1 %32
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: passo 5, imagem 1 %32 UE BOOM 2 Micro-USB Port Replacement: passo 5, imagem 2 %32 UE BOOM 2 Micro-USB Port Replacement: passo 5, imagem 3 %32
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
Conclusão
7 outras pessoas executaram este guia.
Alex Bahm
Membro desde: 01/18/18
2.226 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro de Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
Membros da 2
Autoria de 15 guias
6 comentários
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Responder
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Responder
i too am looking to find the replacement part
Liam Nicholls - Responder
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Responder
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Responder
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 151
Duração total: 8,314
