Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
The battery is located under the top cover of the UE Boom 2. It is held in place by 4 screws and can be replace with a single screwdriver and a spudger.
  1. First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button. Remove by twisting in a counter-clockwise motion.
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. After the D-ring has been removed, remove the  rubber port cover. After the D-ring has been removed, remove the  rubber port cover.
    • After the D-ring has been removed, remove the rubber port cover.
  3. Remove the rubber stripping using a metal spudger. Work around the edge of the rubber stripping slowly prying up the edge. Work around the edge of the rubber stripping slowly prying up the edge.
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. Continue removing the rubber stripping down the side.
    • Continue removing the rubber stripping down the side.
  5. Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. Use a metal spudger to pry up the plastic cap. Use a metal spudger to pry up the plastic cap.
    • Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker.
    • Use a metal spudger to pry up the plastic cap.
    Guide is missing a step as there are no screws under the rubber strip.
    Jack Arnold - Responder
    In the picture, the instructor is taking off the top of the speaker. DO NOT DO THIS. You must take off the bottom.
    Tanner Bilcowski - Responder
    If you make the mistake of opening the top and pulling out the board that holds the power button, what may help you align the board back is undoing the fabric cover clips right on top of the volume up button and gently sliding that board back into place. The connectors aren't as forgiving (yup, it just slides through holes in PCB) as the bottom ones that have tapered female ends so go slow and gently as you can.
    Matthew Ballard - Responder
    Wish I read these comments before trying this step.
    GGAmber - Responder
    Future readers: Do not.... I repeat, DO NOT follow ANY of this article. I now have a UE Boom 2 that is a complete sh@#show! Rubber I can't fix, and scratches all over like you wouldn't believe. Listen to the previous comments instead. I now have to glue the rubber back on to mine.
    tre-rocks - Responder
  6. Carefully un-loop the cable with a plastic spudger and unplug from motherboard. Slowly pull out the battery, and handle with care.
    • Carefully un-loop the cable with a plastic spudger and unplug from motherboard.
    • Slowly pull out the battery, and handle with care.
Conclusão
12 outras pessoas concluíram este guia.
Brandon Yowakim
Membro desde: 18/01/2018
546 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Membro de Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 Membros
8 Guias de autoria
what kind of battery ?and do you have a link to buy one
wrig5235 - Responder
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
https://www.joesge.com/products/ue-ultim...
Frederic - Responder
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
Joseph Murphy -
People replacing the battery be warned, you can buy a battery from China for 17 shipped on eBay, however what this guide does not tell you is one you open it, and re close it, there will forever be a gap on the top and bottom between the mesh and the rubberish spine. I have not since then tested the water proof feature because of this gap. You are warned and he should have warned us as well.
Joseph Murphy - Responder
Missing a step, after removing the rubber you are met with smooth caps on the top & bottom of the speaker, no screws holes
Be careful to unscrew only the bottom part and leave the top part in place (the photo is misleading, he removes the top part). the bottom is where the battery is.
lginoux - Responder
Is this just a standard 18650 battery? Looks like it from the picture.
Tim Ligtermoet - Responder
Will it effect the waterproofing?
Jake Militano - Responder
What have my ue boom ,sound comes on and goes off when is’s fully charged
Wesley Inia - Responder
What's the course of a ue boom when turning it on, sound comes on and goes off again the sound don't finish but cut off not complete sound comes on just half sound only,but it's fully charged
What's the course of a ue boom when turning it on and goes off again the sound comes on just half sound not really the complete sound
Then we buy a new battery or we just replace the same one. Please clarify me here?
GILBERTH IMBUN - Responder
What do you mean exactly? You need to buy a new battery and replace the one in the speaker with the new one.
Elias Bürgisser -
Does Somebody also has this Problem?
I changed the battery, everything worked fine. But when I cranked the volume at the maximum, the speakers suddenly shut down and they only work again after inserting the original battery. I bought two batteries from different sources and both had the same problem. Is it just bad luck or does anybody else has this problem?
Elias Bürgisser - Responder
Doing this will cause cosmetic damage to the device around the base. This does not damage the waterproofing.
Waterproofing is provided by:
A) the rubber cap held on by the D ring protects the USB/AUX ports.
b) The purple O ring under the black plastic cap held in by the 4 Phillips screws.
So, if you put all that back correctly, the waterproofing will be fine.
I found that To more easily remove the top, Re-install the D-ring during step 3, then unscrew it 1.5 turns, and grip it with a pair of vice grips.
The vice grips in combination with the Spudger will ease removing the top cover. BE GENTLE, you don’t want to tear the rubber!
If you remove the blue rubber, and it’s smooth plastic underneath instead of 4 screws, you %@#%ed up, and separated the rubber over-molding from the top plastic.
Adrian Neill - Responder
Thanks Adrian!
Most helpful post here!
Thangfish -
Here is a brand new aftermarket replacement UE Boom 2 battery. It includes all the tools needed for installation and a 1 year replacement warranty!
UE Boom 2 Battery
Mike - Responder
How this guide became “Featured” is beyond me. Some of the pictures show him opening up the wrong end of the speaker, but most importantly the technique shown here WILL break stuff. The way the top/lid is made makes it impossible to open like this without breaking the structure.
It will however mostly go back together, so it is possible to do it like this, just know that it wont be entirely like before. From what I gather the rubber seals are positioned so that the speaker should still be waterproof after changing the battery.
I took a lot of pics of mine after I opened it, shown here: https://www.reddit.com/gallery/iqq59a
erlendds - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 47
Últimos 7 dias: 409
Últimos 30 dias: 1,716
Duração total: 38,594
