Ir para o conteúdo principal
Turtle Beach Recon Controller Motherboard Replacement
O que você precisa
  1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: passo 1, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: passo 1, imagem 2 %32 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: passo 1, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Motherboard Replacement: passo 2, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement: passo 2, imagem 2 %32 Turtle Beach Recon Controller Motherboard Replacement: passo 2, imagem 3 %32
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: passo 3, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement, Face Plate: passo 3, imagem 2 %32
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Motherboard Replacement: passo 4, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement: passo 4, imagem 2 %32
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Motherboard Replacement: passo 5, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement: passo 5, imagem 2 %32 Turtle Beach Recon Controller Motherboard Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: passo 6, imagem 1 %32 Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: passo 6, imagem 2 %32
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
  7. Turtle Beach Recon Controller Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Nothing can be further removed from the motherboard. It can now be replaced.
Conclusão
Mary Goodrow
Membro desde: 03/22/24
671 Reputação
Autoria de 5 guias
Equipe
1Comentário do guia
thanks for posting this!
Sean Malter - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 41
Ao todo: 609
