Ir para o conteúdo principal
Turtle Beach REACT-R Vibration Motors Replacement
O que você precisa
  1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, imagem 1 %32 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, imagem 2 %32 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, imagem 3 %32
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
    Pergunte ao FixBot
    Comentar
  2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, imagem 1 %32 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, imagem 2 %32 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, imagem 3 %32
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
    Pergunte ao FixBot
    Comentar
  3. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, imagem 1 %32 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, imagem 2 %32 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, imagem 3 %32
    • Be careful not to damage the vibration motors by dangling the wires.
    • Place the motherboard down on its back.
    • Grip white rumble motor connector and pull it directly out of its socket to disconnect it from the motherboard. Repeat for the other motor.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 418
