Ir para o conteúdo principal
Turtle Beach Elite Pro Headband Replacement
O que você precisa
  1. Turtle Beach Elite Pro Headband Replacement, Headband: passo 1, imagem 1 %32 Turtle Beach Elite Pro Headband Replacement, Headband: passo 1, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the three 4.5 mm screws from the adjustment plate on both the left and right side.
    • When reassembling the headband, make sure the left and right sides of the headband line up with their respective designations.
  2. Turtle Beach Elite Pro Headband Replacement: passo 2, imagem 1 %32 Turtle Beach Elite Pro Headband Replacement: passo 2, imagem 2 %32
    • Lift the headband from the headset and replace with the new one.
Conclusão
3 outras pessoas executaram este guia.
Alexis Uribe
Membro desde: 03/24/17
510 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S5-G1, Williams Spring 2017 Membro de Baylor, Team S5-G1, Williams Spring 2017
BU-WILLIAMS-S17S5G1
Membros da 3
Autoria de 8 guias
10 comentários
Where did you buy the piece to replace
Audiz - Responder
I need you urgently, please
Audiz - Responder
I need the hand band where can u buy one
Anthony Lara - Responder
I need that headband piece as well! Where do you buy it?
Imanol Caba - Responder
Where can I buy the replacement headband.
loged45 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 48
Duração total: 7,296
