Introdução
This guide will teach you how to remove the side plate from the headset. You can use a metal spudger or your fingernail to remove the side plate. If you decide to use your fingernail, be warned that it will be a bit more difficult.
O que você precisa
Find the small notch on the side (left or right) of the side plate.
Insert the metal spudger into the notch.
To put the side plate back, simply snap the side plate into place.
Uma outra pessoa concluiu este guia.
