Ir para o conteúdo principal
Turtle Beach Ear Force XO One Speaker Replacement
O que você precisa
  1. Turtle Beach Ear Force XO One Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Start with the ear padding facing up.
  2. Turtle Beach Ear Force XO One Speaker Replacement: passo 2, imagem 1 %32 Turtle Beach Ear Force XO One Speaker Replacement: passo 2, imagem 2 %32 Turtle Beach Ear Force XO One Speaker Replacement: passo 2, imagem 3 %32
    • Remove the ear padding by separating the fabric piece from the plastic headphone piece.
    • The leather padding will slide off the plastic piece holding it in place. Don't be afraid to pull with a little force.
  3. Turtle Beach Ear Force XO One Speaker Replacement: passo 3, imagem 1 %32 Turtle Beach Ear Force XO One Speaker Replacement: passo 3, imagem 2 %32
    • Use a Philips head screwdriver to remove the speaker cover.
    • Be careful the speaker is attached to the chip inside by wires.
    • The recommended screwdriver bit size is a PH 0.
    • Once the speaker cover is removed, the wires can be cut or de-soldered.
    • Remove the speaker.
    • Insert the new speaker
Conclusão
Uma outra pessoa concluiu este guia.
Stephen Reilly
Membro desde: 10/28/15
128 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Membro de UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
Membros da 3
Autoria de 6 guias
Um comentário
what speaker can i use as a replacement and where can I buy one?
Tristan Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 2,804
